Skoda octavia scout
2010 octavia scout. Problems , starts , cuts out . Drove for 500m at most the cuts out won't start again for a few minutes , then cuts out again . Sometimes just won't start again , only starts when dpf light come on in ignition , after cut out dpf light doesn't light up on ignition and doesn't start . Ecu checked OK.  Fuel filter etc all done by mechanic , clutching at straws now any ideas or anybody had same .
If your mechanic can't fix it get another who can.
I suspect fuel starvation/DPF clogged.
Won't regenerate on computer , cuts out!
Fuel pump power getting cut causing cut out ?
