Fabia 1,9TDI VRS 2005 Fault Code P1255 coolant temp. permanent short to ground
Have replaced coolant temp. sensor to cure previous cooling related fault and am now getting the above. I would like to be able to test the continuity  of the two wires, brown and green. Brown checked out easily from sensor plug to battery neg.
How do I check the green wire which I assume terminates at the ECU without any connectors in between?
I have read in past threads that people connect to the appropriate pin in the ECU multiplug but the Haynes manual warns that unplugging will result in the need to recode by Skoda dealer!
Any assistance will be most appreciated.
  • Sponsor
If it's a short to ground don't you just need to check if the green wire has continuity to batt neg, which it shouldn't have?
Can look up ecu pin number, but Haynes comment sounds un-fact-based I'd say.
  • Sponsor
Pin 1 at CTS, blue wire, terminates at ECU pin 112
Pin 2, brown, goes to ECU pin 104
Many thanks to Pete-Ex-Wino for his comments.
I'll carry on with my investigation armed with his info. and post the results.
  • Sponsor
Also test the resistance between the sensor pins during your checking, just in case it has failed by leaking into its insides, shorting out wires/pins.  Can be tricky to get meter probes in there to make reliable contact without touching each other.
Checked and there is no sort to earth on the green wire which leads me to suspect the sensor itself. This is a recently purchased and fitted item and is made by Cambiare who I believe are a proprietory brand. Nonetheless, even the best can fail as we all know.
I am a complete novice with a multimeter. Please advise what range I should set the ohms reading in to get a meaningful reading.
It would be worth watching a few videos on YouTube on multimeter use as there are a few decent ones out there that will help you and explain all that :)
Always start with the highest range on a multimeter if you don't know what to expect, then you can turn it down until you get a solid reading.
Many thanks. Will work again on problem tomorrow.
