Octavia 5e rear driver window error?
Hi, I have a problem with my Octavia 5e 4x4 1.6 TDI. The end positions for the rear driver window can't be learnt, so I cannot one click pull up/down this window. What really annoys me, is that I also can't control the windows from the key because of this problem. Moving the windows by holding the corresponding button (on the front and rear door) works fine. I tried pulling and reinserting the corresponding fuses and removed the door cover, but found no obvious faults.
There is also a DTC, that I can't find any information about:
============1==============
589834
Raw code: 09000A
ECU: 42. Driver door electronic equipment
Status: Test failed, Confirmed
Skoda: B131F01: Rear window regulator, driver side
Electrical error
Status bits: 1
Priority: 4
Frequency: 1
Unlearning index: 125
Would replacing the window actuator assembly solve the problem? Do you guys have any advice, something I could try?
Replacing the window actuator assembly indeed solved the issue.
