Lost road wheel fixing
Hello everyone,
(my warranty is still on)
I've just noticed I had lost road wheel fixing.
Can I buy it online or do I have to go to official Skoda (to not break warranty) ?
You mean a wheel bolt?
Any scrap yard or dealer for VAG cars.
@New11  If the wheelbolt do you suspect someone has pinched it, maybe because they lost one?
Has the car been in at a garage or tyre fitting centre?
Have you checked all the others on a the car are correctly tightened?
Even if someone has pinched it I cannot do anything about it 😞
I just want to fix it.
Is it the wheel bolt that is missing or just the plastic cover?
Thanks, AG Falco
1 hour ago, New11 said:
I googled it and found the following list:
https://www.buycarparts.co.uk/skoda/kodiaq-ns7/138112/10313/wheel-bolt-and-wheel-nuts
but they look differently - which are the correct one ?
Genuine (according to the seller) VW Audi Seat Skoda WHT001812
https://www.ebay.co.uk/itm/173689662073?hash=item2870b5ea79:g:sWwAAOSwzgtcEnba
Febi 09801 is sold to replace OEM part numbers WHT001812 and WHT002437
https://www.ebay.co.uk/itm/173796158364?hash=item28770eeb9c:g:eM0AAOSw9y1iE8uE
https://www.autodoc.co.uk/febi-bilstein/1871560
FEBI BILSTEIN 09801 Wheel Bolt M14 x 1,5 Ball seat A/G 48mm
Article number: 09801
  • Spanner Size:17
  • Length [mm]:48
  • Thread Length [mm]:27
  • Wheel Fastening:Ball seat A/G
  • Screw length below head [mm]:27
  • Colour: Silver
  • Fitting Position:Front Axle, Rear Axle
  • Weight [kg]:0,062
  • External Thread [mm]:M14 x 1,5
  • Quality/ Grade:8.8
  • Surface:Zinc-coated
  • Bolt Head-/Nut Design:Male Hex
  • Material:Steel
  • for OE number:WHT 002 437
  • Diameter [mm]:23
  • FEBI BILSTEIN:Wheel Bolt
  • Item number:09801
  • Manufacturer part number:09801
  • Manufacturer:FEBI BILSTEIN
  • EAN number:4027816098010
Edited by Carlston
@New11 I knew you can do nothing about it after one is gone, so have you checked the others are tight?
Is the security / locking bolt still fitted and is it one of the other 4 that is lost?
Edited by roottoot
