Power Steering Issue
@ScottB832I don't know if you got to the end of the steering issues? I sorted mine out today! After much umming and urring I ordered a rack, ripped the old one out on my driveway and found this. Fitted new one put some spacers in the dog bone mount to give it clearance and tested it. I've never felt fabia power steering but it's nicer than my 22 plate Vito so I'm over the moon.
I bought the new one as a service exchange for £150 on eBay! 3 years and 60k mile warranty.
Hope this helps you out mate, if you haven't already sorted the steering in your car 😉
  • Replies 54
  • Views 8k
  • sepulchrave
    sepulchrave
    It's very simple, the PAS pump uses a massive amount of current, around 60A peak, if the alternator or the battery are not in tip-top condition then the reference voltage will quickly sag under this l
  • Breezy_Pete
    Breezy_Pete
    That sounds really very unlikely.   The PAS system is pretty self-contained. Angle rate sensor plugs straight into PAS module; permanent power wiring; an ignition-on wire and a pair of CAN d
  • sepulchrave
    sepulchrave
    Us technical types don't really care about aesthetics if a tool works well and VCDS works better than almost anything else for VAG vehicles.   You creative types worry too much about fonts a
Is that damage from a too-long dogbone rear bolt? Is that the bottom side? Can't quite work out orientation.
Yeah it was the dog bone mount, it's the underside
Bolt should be 61mm long, bet someone put a 65mm gearbox to block bolt in by mistake while doing a clutch change.
Hacksaw?
I think you are right...
I fitted some spacers and it's nicely out of the way of the rack now! But I wouldn't be surprised if that 4mm was right since it was 3 or 4mm on the spacers I put in
