What is this bolt in front of the engine?
3 hours ago, Thefeliciahacker said:
yeah i know what it means, i have C2 + 2years exp in the UK😅
OK, fair enough.  Didn't want you thinking I was being intentionally or unintentionally rude or British humour.  I have E5 but lots more experience.  😁
Bad news...
I suspected from another source of leak and finally found this:
Now please if anyone knows, what is this mysterious recess?
This picture above is from my engine. I used a mirror to take the picture so it's inverted. The mysterious recess is well hidden from eyesight. It's just below the bolt I've asked before. I couldn't notice this before because it was covered in oily muck.
It's angled downwards. I'm afraid it might be some kind of over pressure relief plug. If that's so, I think it's impossible to fix it without removing the engine?
I can't imagine removing the engine because of this. :crying:
I've found something about it.
It's number 32.
It's an 8mm plug. Like a freeze plug but installed on an oil channel. N90796301
Now, how would you replace an 8mm plug on an oil channel without removing the engine?
A hexagon inox bolt with copper washer?
No, it's a metal cap. Like these:
ctrp_0811_04_z-freeze_plugs-installation
But very small diameter. Only 8mm.
Yes it's an oil gallery machining port.
I would advise to either find a freeze plug or tap it and install a SHORT BOLT
Drill a 2mm hole insert a wood screw and pull like mad
Shouldn't I worry about metal dust inside?
Great ideas by the way. I'm glad you are active again. I missed your posts.
should you?
i mean you can use grease,
low rpm and you have an oil filter as well
dont worry friend thefeliciahacker is not abandoning this forum
