Skoda Fabia Mk1 1.4 8v mpi ignition coil replacement
Hello guys,
I'm thinking about replacing my ignition coil with a different one that works on 1.6 mpi engine... Is it a good idea?
No, it won't work properly, just replace yours if it's faulty otherwise don't bother.
You know I'm suffering with my spark plugs, they die so quickly and make that sparking sounds. I always install the genuine spark plugs but also...
As @sepulchrave says. Also, make sure you are actually using a genuine VAG coil assembly.
@KenONeill thanks, I will do what you've just said, I think 🤔 the prob's. from my ignition coil. I saw this 👇🏽 picture online that's why I was wondering about the adjustment.
  • 2 years later...
what happened here ؟
