Pedalbox installation
Can anyone tell me where I would connect a Pedal Box to on the Yeti?
I have had a look above the accelerator pedal but can't see any obvious connecting cables.
I am considering getting one of these  - DTUK® PEDAL BOX.
Many thanks
There should be a plug & socket just above the accelerator pedal to which you insert the PB fits.
That's what I expected but I can't see anything unless its the socket underneath the accelerator pedal unit itself?
Mine is a 2015 model car.
@FlatjackWith what engine / gearbox?
2.0 Diesel, 4x4 with DSG
Thank you
The plug ( item 2 ) can be seen here…
Here's 'without' and 'with' photos. 👍
A simple matter of removing one plug (by sliding the red locking pins 'outwards' and then attaching both the PB connectors to re-make the circuit.
So this is what I am faced with, do I have to remove the plastic cover above to expose the connector?
Thanks everyone for such brilliant help, as always. Fantastic.
  • 3 years later...
Digging up an old post I had a look last week in an attempt to fit a throttle controller (to me recently purchased yeti outdoor) and couldn't find it but the pics in thread will help when I check next time.
This was all I was greeted with and connections up under the dash itself
If anyones still here in Yeti area can u please let me know the connection is under this section? I'm struggling to get the carpet folded back to access
