mk2 fabia vrs P10AD00 fault code
Help needed .. car lost power no eml light came on. turned ignition off then back on started and drove fine, eml light came on . read fault codes and it came up with P10AD00 magnetic clutch for mech charger-open circuit i booked car in for a replacement magnetic clutch/waterpump the car now goes into limp mode when accelerating . plugged diagnostic in an read codes list as follows P10AD00  P10AC00  P001000  P024300  P044400  P003300  has anyone had this problem on their vrs
Welcome.
Sorry for been daft but has the car had the new water pump or is it just booked in for getting fitted?
Do not accelerate with it until you get the car fixed if not done.
I did 1,100 miles including the North Coast 500 with the Turbo disabled while waiting to get a new WP.   Great MPG at 60 MPH.
PS
Do you also have a Octavia vRS 2.0 tfsi?
Edited by roottoot
3 minutes ago, roottoot said:
Welcome.
PS
hi mate i had new waterpump fitted on friday
5 minutes ago, roottoot said:
Welcome.
PS
i did but sold it a while ago,wish i still got it
8 minutes ago, roottoot said:
@UrbanPanzer@Mickmartinor @thomasaspinmight be able to advise if they see this.
Hi mate sounds stupid but if you have already had the magnetic clutch fixed have you checked the electrical connector to the magnetic clutch is plugged in correctly ?
7 minutes ago, brombat said:
genuine vag part local garage i use
Hi mate if it’s a genuine part it’s either faulty from factory or my theory is that they will have damaged the wires/connector that go to the magnetic clutch on fitting it , did you replace water pump as a precaution or was the magnetic clutch faulty and that’s why you got it replaced in first place if so maybe the magnetic clutch was never faulty and it was a wiring / connection problem
what happened is i lost power limped back to work plugged diagnostic in and came up with P10AD00 code  so i booked car in for a replacement waterpump genuine one fault code is still present along with P10AC00  P001000  P024300  P044400  and P003300 the garage have checked connections and all seems fine
Did the remove the original codes ? Try removing codes and see if it does the same thing tommorow if so they need to replace the water pump again at there cost did they check the connections with a multimeter ?
Does the electromagnetic clutch have it's own fuse on top of the battery?
i dont know buddy
1 minute ago, brombat said:
i dont know buddy
Check fuse 28/29 sepulchrave is correct as usual 🔥👍
they removed all codes this afternoon started car and all codes shown returned
Check my latest reply above mate ^
thanks mate ill get garage to check fuses etc ctc tomoz
48 minutes ago, brombat said:
i dont know buddy
do you know what amp the fuse is
thanks for advice  it was a dodgy electrical connector in the end
car sorted now it was the electrical connector not pushed together propely
