Viewing my service record ??
Is it possible for me to view my Skoda service record as stamps in your book are a thing of the past ?
You can if there is a record of servicing within the dealership network or someplace that added it online. Someone will be able to tell you how.
Easy enough though to ask at a Skoda Main Dealers or Skoda Customer services to give you the record of Servicing, Service Campaign work or warranty work.
It's the dealership info I'd like to access, I currently have a print out but would like to keep an eye on it
Get it from them.
Does the print out not show everything from the system?
Are you still using a main dealer to service your car?  Get them to print out what they do for the records.
Is this the Mk2 vRS?
What has been done like the spark plugs being changed, did your car ever get '34H5' done to the DQ200 DSG or was it one that did not need it.?
There should be a sticker in the spare tyre well if done.
@roottoot
Thanks I'll check the spare wheel well, I believe I have a full print out from the dealers but I still want to see it / keep updated, I'm looking for a Skoda indi in my area (co Durham)
The Indy will need to have licensed equipment to update service records.
I am a bit confused as there nothing to keep up on unless your car is getting work done and somebody inputs onto the system.
What are you gong to keep updated on?
Has your car had the brake fluid changed or tested for H20?
Have you been changing the pollen filter or checked it, or the air filter?
1168293554_37335614_Screenshot2021-09-14at07_38_18(3).webp.ee5b8a609f78b3b2f42441d7532010fa.webp
Edited by roottoot
I just want to ensure the work is correctly recorded, all servicing up to date as far as I know ???
How many miles has your car done?
What servicing is up to date, Minor and Major services?
Do you have any record of the Spark Plugs being changed or the brake fluid changed?
This is a record taken off the system.
Edited by roottoot
cheers @roottoot
85,000 miles
Services and service inspection up to date
yes spark plugs been done (by dealer in my ownership) this is why I want to keep an eye on the service history
