Amundsen - EEPROM Sat Nav Component Protection Removal
Hi, I have a Skoda Yeti (2015) and I purchased from a breakers yard a Amundsen MIB2 (5L0035680A) head unit (also from a 2015 Yeti) as mine did not have Sat Nav. I installed it OK, upgraded the antenna for SAT Nav and DAB capabilities. But after many attempts including taking it to 2 Skoda Dealerships and paying an ODIS engineer, I still cannot get the Sat Nav to work, it opens and you can see the location where you currently are and then it’s says, "Please Insert Medium with Valid Navigation Data". I have purchased 2 SD cards 5LO 051 236 BR from different suppliers but they both show the same error. All other features Phone, Bluetooth DAB and FM radio all work.
I have also had installed the “Green Engineering Menu” by an ODIS engineer who has disabled the feature which checks the Sat Nav SSD card for a CID activation code. But the Sat Nav still won’t load, it still states "Please Insert Medium with Valid Navigation Data"
From what I have picked up from the Web, the head unit I have must have a EEPROM security chip built in, looking at YouTube videos I’m not sure what you have to do, remove it, or does it need reprograming? or in fact where it is actually located.
Does anybody know of anyone or a company that deals with EEPROM security chip’s, I live in the West Midland’s, but I would be willing to travel.
Any help would be very much appreciated.
From what I know the only things stored in the head unit should be the VIN and what release codes for various parts like android auto etc will be stored.
I would rather focus more on what's on the SD cards, are you able to show a screenshot of the file/folder layout, and attach copy of the file that should be in the root directory.
Did you update the files?
Did you use PC or Mac to do any map updates?
Have you checked whether music can be played off a 'normal' SD card? This will check whether the problem is the SD card reader hardware.
I did think that also last night too, but didn't answer until now and forgot.
They are sensitive to Mac's adding files to the card for maps, be interesting to know the outcome of our questions.
Hi Thanks for replying.
I have tried various version of maps, and I have downloaded the correct maps from Skoda's portal, I use the VIN number from the donor car that I got the head unit from  so I know the maps are correct. I have also tested both SD readers with music and photo's so I know there OK as well. I use a Windows 10 laptop to copy the map data to the SD card.
Attached are 3 of the SD cards I have showing a snap shot of the roots of each one, I have another one in the car but my wife has the car at the moment,
I am just out for the day now, so I won's be able to reply until tomorrow.
Steve Collett
I don't suppose you have the VIN of the donor car to hand?
The maps on my MIB2 are not like yours I can say for certain, nothing in the root folder and only MAPS folder.
You should be able to use either of the maps https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_1910_V16.7z
or https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU1_1910_V16.7z
First link will need 32GB card
Second link will fit 16GB card
Try and report back your findings on using latest maps.
We could also look at your current firmware loaded on, though any updates will wipe out any "adjustments" made by the different garages.
Perhaps check this out just to see if there is an update, and decide what to do.
