Flickering head lights
Hi guys looking a bit of advice my headlights on 2019 sel executive have started to flicker at times not always but noticeable at traffic stops .would this be a head light bulb replacement needed (£85 PER BULB ) ? .
thanks for any help given .
Phil
It could be the altenator dropping Voltage at idle, but also the bulbs nearing end of life perhaps yes.  If you have HID headlights, the D1S I think from memory is the bulb fitted, and I would advice you replace the pair.
If you can confirm if they are indeed HID, that would be good.
Yea thanks for that info they are HID headlights replaced the battery around 3 months ago also .but interesting about the alternator could be the cause I see no flickering while driving and when the car moving even at slow speeds it seems to stop .I do lot of night driving so dont want unit failing while I'm out in the sticks .
Thank you Phil.
Could be the luminaires, or could be a CANBus error.
Was the replacement battery the correct type and coded to the vehicle.
There are very recent as well as old threads on batteries and needing coding in, do you remember who did the replacement?
Not saying it is this, but can upset the car if not coded after change, seems a tad early for a battery replacment.
The Superb uses D3S Xenon bulbs.
.....and they're a royal pain in the behind to remove/replace!!
Edited by JR RS
Thanks guys for replying. I changed the battery myself after stop/ start  stopped working and i got low battery warning i got the correct one from euro car parts and paid the extra for better quality  .im a taxi driver so car  driven to 1000 ml per week and lot of  short journeys inner-city work.
did not code the battery could this be the issue ?.
Thanks phil .
Start by getting it coded into the car, it will eliminate that, and save any issues you may have because of it.
My mechanic said whoever designed those light housings needs shot.  Pain in the arse to change
All Skoda had to do was provide a panel which can be removed like the A6, but I think it was a case of Simply CBA
I’m changing my bulbs soon as they’re pretty poor, I just don’t know whether to get Osram NBL or CBN
Edited by Danoid
  • 3 years later...
i know this is an old thread but did you get to the bottom of this ? i have the same issues and it's like my lights aren't on at night sometimes ! i had the battery replaced in january and a new alternator last week and no improvement , passenger side the worst !
Hi guys sorry I know this is an old thread. I had the same issues and changed my bulb but its not working. A mechanic told me it could be the balast or something. Can it b3 checked without ordering a new one or taking the whole light out as its a ball ache.
@JR RS can confirm but I believe he said the ballasts can be swapped around for testing
Definitely can swap around the ballasts to see if it's the issue or not.
The ballast is accessible from the top, via the engine bay. It sits on the back of the headlight. Silver looking metal square thingy.
If the problem moves to the other side, then u know the ballast is the issue and it can b replaced.
Recently Browsing 1
