Octavia Mk3 VRS Space Saver
Could anyone confirm if an 18" space saver from a mk5 Golf fit a Mk3 Octavia VRS?
After reading the various threads I am aware that it needs to be an 18" wheel to clear the caliper. Just want to make sure it will be the right offset etc. from a mk5 Golf.
Thanks.
As you can see below, 17" wheels can be fitted to the Octavia MK3 VRS. The Octavia MK3 facelift diesel VRS has smaller front 312mm discs, so 16" wheels will fit those cars.
205/50R17 tyres fitted to either 6Jx17 ET45 or 6Jx17 ET48 rims are approved for snow chains. 225 tyres are too wide for snow chains on the Octavia MK3.
You could use a 205/50R17 tyre fitted to a 6.5Jx17 ET38 5/112 57.1 steel rim from the Kodiaq. That will clear the front brake calipers on the 340mm diameter front brake discs.
6.5Jx16 ET38 5/112 57.1 steel rim
https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=672860434273997936%3A%3A0001
Skoda Octavia 2017 2.0TSI 245PS VRS
– Generation: Mk3 A7 (5E) Facelift [2017 .. 2022]
– Market: EUDM
– Power: 241 hp | 180 kW | 245 PS
– Engine: 2.0L, DHGA, I4, Petrol
– Options: RS
– Center Bore: 57.1 mm
– PCD: 5x112
– Wheel Fasteners: Lug bolts
– Wheel Tightening Torque: 120 Nm
– Thread Size: M14 x 1.5
– Trim Production: [2017 .. 2020]
Tire
Rim
Vehicle's recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).
225/40ZR18 92Y 7.5Jx18 ET51 2.2 / 2.3
Recommended for winter205/50R17 93H 6Jx17 ET48 2.2
Recommended for winter205/50R17 93H 6Jx17 ET45 2.2
225/45ZR17 91Y 7Jx17 ET49 2.2
225/35ZR19 88Y 7.5Jx19 ET51 2.4
https://www.wheel-size.com/size/skoda/octavia/2017/#trim-20tsi-eudm-241
Skoda OEM 6Jx17 5/112 57.1 alloy rims
5E0071496A Aluminium rim 6Jx17 ET48 CRYSTAL
5E0071496A 8Z8 Diamond silver
vbbb.jpg?v=1612950049
5E0071497E Aluminium rim 6Jx17 ET48 CRYSTAL
5E0071497E FL8 Black metallic
76766776.jpg?v=1612950180
5E0071497B Aluminium rim 6Jx17 ET45 FLASH
5E0071497B 7ZS chrome coloured metallic
0870709.jpg?v=1617868280
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/805/0/071/71070
Edited by Carlston
Thanks for the above Carlston. Didn't realise a 17" would clear. I am going to stick with a space saver though as they seem to be cheaper to pick up used.
3.5Jx18 ET25.5 steel rim 1K0601027AP
1 1K0601027AP Steel rim for
space-saving emergency wheel
3,5JX18H2 ET25.5
  1K0601027AP03C rally black
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601012
3.5Jx18 ET25.5 steel rim 5Q0601027BC
1 5Q0601027BC Steel rim for
3,5JX18H2 ET25.5
  5Q0601027BC03C rally black
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/585/6/601/601012
Complete spare wheel 18"
Edited by Carlston
