Skoda 1.6 TDI brakes
Hey, I have a Škoda mk2 1.6 TDI estate and I want to completely replace the brake set. Front and back. ( Because rust wins ) and they would need to be revived. That's why I want to ask what would you recommend? I am looking for something of good quality. I also thought about a larger brake disc diameter. (rim size R16) Of course it is not a super sports car. Is it possible to experiment a little to make it brake better and look good. Thanks for any advice and tips.
Mine had 256mm discs up front and I think around 210/212mm rear, upgraded to 312mm front from a early Audi TT only issue is you have to source fabia vrs front knuckle or hub to have the correct bolt pattern to mount the calliper carrier, rear was updated using new front discs off my car 256mm vented and 1st gen Octavia vrs rear calipers
