Back to stock turbo - car cant go over 80nm torque + N239 fault code
I have switched back to my original turbo after almost two years with an RTMG hybrid 240rs .
Process was going smoothly but when I took it on a test drive it had no power..
Live data from OBD dongle showed 1.37 bar boost when flooring it but max torque was 80nm , played with the wastegate actuator seems to be ok , removed the charge pipe and intake throttle body was moving ok.
Diagnostic tool later showed fault - 01282 - intake manifold flap , change-over valve (N239) .
Has anyone else faced this problem? Any solutions?
thanks.
Edited by Eladshaul
