About to buy a 1.4 SE Sport estate
Found a car I like alot and will be purchasing it.
Will in all liklihood fit a B12 suspension in the future as felt a bit soft compared to our current car as very impressed with that on our 06 vrs. Can anyone confirm which kit, 50mm or 55mm
I didn't check which mode it was in but suspect eco when I test drove it. Does sport make much difference
No CD player I could see but reccomendation for sd card to load with music, does it need to be a fast card, is there a max size 64gb or 128 gb?
Tyres are 225/45/17 w currently
Going to fit crossclimates 2 but do I need V W or Y rated tyres given v is rated to 149mph and car max speed is 134mph ....
How do check map version I will ask for them to be updated.
Thanks all
Likely 50mm but should be easy enough to check. 55 was mostly fitted to vrs and 4x4 models.
Thank you.
