Retrofit Questions - Maxidot and MFSW on pre-FL
I've been doing some reading around retrofits for pre-FL Mk2s and I'm trying to find out a bit more.
For context, the car is currently standard apart from an RCD330 head unit which works great..
I'm looking into fitting maxidot and I've found a pre-FL diesel VRS cluster for sale.  I'm fairly confident I understand what's involved in fitting this.
What I'm wondering is whether fitting a facelift maxidot cluster is difficult, and whether this would give me the option on future of fitting a FL MFSW and having it work fully with the steering wheel controls.
I'm also wondering how well this maxidot/MFSW combination would integrate with my RCD330 unit, both with native audio playback/phone connection and also when using CarPlay.
Thanks in advance to anyone who can help!
Whilst I can't comment on the retro-fitting, my pre-FL Scout has Maxidot and MFSW and I've looked at retro-fitting an MFSW to t'other halves facelift Mark2.
If you're handy with VCDS or know someone who is, fitting the clocks isn't a bad job, it's just coding them.
You'll also need a slightly different stalk that allows you to access the menus within the Maxidot, as the standard stalks just have a rocker switch at the end, where as the ones for Maxidot have a rocker, but also a button on the underside that's your 'Enter/OK' button.
To fit the MFSW you may need to change the airbag slip ring and you'll need to check if you have a highline steering wheel control unit to support the additional buttons that an MFSW brings. Again. Coding will be necessary once everything is installed.
Regarding operation of the radio, I can't comment, as I'm running the standard Stream MP3 in my Scout, but again I can't see why it wouldn't work if you've fitted the correct slip ring, controller and done the appropriate box ticking in VCDS.
I'm guessing you mean your car has a FL MFSW? Does this work okay with your pre-FL Maxidot? As I've heard of the radio/volume buttons working but not Maxidot controls when fitted to a pre-FL car.
Sorry for the slow reply.
My Scout has MFSW from factory, so it's a pre-FL steering wheel fitted.
