Bolero Replacement for Yeti 2016
Well I've seen a few posts about this but most of the links I can find for aftermarket Bolero replacements are for older Yetis.
I wonder if anyone could point me in the right direction to replace the Bolero unit.
It has parking sensors and a reversing camera attached.
Amazing how you get used to having a reversing camera - I bet there are a lot of small dogs and little kids alive today because of them.
I live in Oz. The Yeti was 28,000 $Aus new and the dealer wants around $4000 to replace the Bolero!
Very happy with the car otherwise.
thanks in advance for any help.
regards
Andrew
Sorry forgot to say I have tried holding the buttons down left side - right side, right and left side etc for a reboot, That worked for a while but not now.
I have pulled out the fuse and replaced and disconnected the battery for 10 minutes or more.
The Bolero unit turns on if I am lucky, works for twenty seconds if I am lucky, then dies.
The later touch screens are 1) expensive and 2) becoming increasingly frail with age.
There is an older OEM unit that is very reliable, search for RNS315, or Amundsen+ .
I have the bluetooth, DAB version with 48Gb of music on an SD card in both my Yetis, maps are loaded onto the HDD.
Thank you for that blackb1rd!
I'll check them out.
I wonder if they need a special code or they can be fitted without one?
cheers from oz
Andrew
A code costs £10 on eBay and usually takes an hour - just provide the serial number.
To be honest most of the stereos I've bought have had the code written somewhere on the unit itself - usually underneath (sneaky high security option!)
Love the sneaky security. Ha ha thanks for that. much obliged for the info :)
cheers from oz
