Battery sensor wire routing?
I'm confused by that, pin 3 seems to go to the right dipped beam headlight bulb, so shouldn't connect to batt positive?
What range is that meter on, in the pic where you're on pin 6, and is the probe definitely getting in there properly, and where's t'other probe?
Can't you just run that wire along the existing loom, out through/near the grommet that takes the loom out of the scuttle into the bay near the ECU, and splice into the fuse wire after following the loom from there? May be hard to do super-neatly, but I'm not that fussy. 😁
  • Thanks 1
