Skoda superb error jackpot?
Good afternoon,
So was driving today as usual no issues, and after parked a car for 30 minutes started it again, but noticed that the revs seemed lower than usual, and the car acceleration didn't seem the same as well. There were no lights on the dash.
I had a Carista OBD reader and after a scan found quite a few issues, which all seem quite serious.
Is this something has accumulated over time, or could all these triggered by one thing?
As well would appriciate where to start and is it possible to fix at home?
Thank you in advance
vk82VhhcRumlI6VTisQdqA.thumb.jpg.2b8be60df3fee231fd09691ee6309705.jpg-BU76JqySByo4XqEeIkfGQ.thumb.jpg.790737da289643131155c02907c4a952.jpg
P0016 points to a stretched timing chain (especially for a 1.4 TSI...). I would go to a VAG-specialist or -dealer to have it looked at asap. If the timing chain jumps over the gears, you need a new engine block...
Also the fuel pressure is most likely generated by the cam-shafts as well (at least, that's how it works in the 1.8 TSI), so there is definitely something wrong in that area.
What does a VCDS-scan say?
Hi Thanks for the reply.
All I have is that Carista scanner, called local garage and was told that they are crazy busy and the earliest could get in is next week, apperantly same situation around. I have parked the car next to the house and have no intention to drive, do not wan't to make it worse. After cearing all the errors now only the fuel pressure ones come back, hence wise thought to get a new high pressure pump.
At the moment have booked a rental car for the next week. Is there any chance to eliminate high pressure pump or timing chain?
What engine do you have?
1.4 tsi, 90k miles.
