Front Indicator acting strange
Hi
I´m having a frustrating issue. My front right indicator as acting abnormal
when I push the open or close button on the key fob it blinks like the rest of the car but then it like fades up and down
the fading happens in the same pattern as the "pump" is making a sound
it does also fades up and down if the car is unlock and no ignition
then the same pump is making some noise and the indicator i fading
is there any body that have tried this issue or is having any idea of witch pump is starting up when the car is unlocking and locks?
i have attached a video with the issue
Thanks in advance
Oliver
Edited by Faxesnifer
I believe that's the low pressure fuel pump.
As above. The FP activation is the low pressure lift pump under rear seats.
Suspect you have a wire fault, earth point fault or connector plug fault somewhere.
Does anything electrically not work. If so. Start there. Otherwise indicator loom I guess I would start testing.  Maybe fuel pump loom as well if no joy.
