front windows
hi all, i need a new electric window switch drivers side is doing silly things passenger side works fine and ive replaced the drivers motor for new can anyone help where i can source one from the ones on ebay dont seem to match ie pins on back of switch
Are you sure its not the door wiring harness at fault ?
Any Skoda dealership should be able to get one for you.
I can find the part number for you next time I get up.
Have you still got the old motor?
Edited by Breezy_Pete
was trying to avoid main dealer prices oh well will get quote, binned the old motor whys that?
not checked door wiring as of yet crucian, will check first cheers
Last time I bought a genuine switch pack it was somewhere around £35 I think, so not hideously pricey.
I have a repair service for window motor modules, so would have given you some cash for your old one, to fix up and use as an exchange unit.
Part number for switch pack assuming manual rear windows appears to be 1J3959857A.
About £50 retail for genuine now sadly: 1J3 959 857 - LLLParts
With the part number you may find aftermarket ones that are perfectly adequate though.
