error cod vcds
Recommended Posts
Hi all,
i  bought (about 3 4 weeks ago ) a skoda rapid  spaceback 2018, on scan with vcds this 3 error codes appear.
I understand the error on the radio, need to find out where the amplifire is, but I did not find online explanations for the errors. Can someone help mi with explaintion ?
Thank you.electric.pdfradio.pdfengfine.pdf
Link to comment
Share on other sites
Electric.pdf appears to refer to the CanBus gateway module 6C0 909 901 A. The other appears to be a motor control unit. Given all errors have occurred only once at about the same time, I'd keep your VCDS results logged, clear all DTCs, and wait to see if it reoccurs. Chasing spurious and intermittent VCDS fault codes is rarely productive unless the fault is manifesting itself on the car. Your radio issue, for example, may be obvious if you have no, or poor, digital radio reception.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
