Skoda felicia radiator fan !HELP NEEDED!
56 minutes ago, Papez said:
Did you drive the car after filling up the coolant
No in situ revving it up.
Measuring with an analog thermometer the temperature on the expansion tank was 90c.
Dp you think this fan switch is a good choice?
That video shows the current set up behavior
Yellow ring coolant sensors never worked good in my Feliica.
Have you checked the pins in the ECU plugs for signs of corrosion?
The original was yellow
Finally got the system to work properly.
I used a
87-79
93-85 thermoswitch.
The system now works on first speed at 95 and cuts off at 88
So yeah the delta is 8 kelvin.
If you want it to run let's say at 90c
You have to choose a 82c thermoswitch.
To find the real operating temperature of the vehicle just add 8 to the temperature of the thermoswitch.
That was the trick.
Maybe keep the other switch for summer when ambient temps are higher and the delta may be rather less. 🙂
Yep will keep that in mind!
I used a
87-79
93-85 thermoswitch.
That was the trick.
That's great :) I think this is how it should've been from the factory..
Mahle has a 5 'C gap for example 75-70, 80-85, 85-90 etc.
2 hours ago, R_Blue said:
Another good candidate is Behr TSW 32.
that was the one I had originally, too high
It's 85-93 'C, not good for our climate here.
36 minutes ago, R_Blue said:
TSW 33
Yes this one I wanted to fit but was out of stock in autodoc
Yes I got away with a 2 speed vernet I sourced locally.
