Continually running cooling fan.
Hello Oricals, happy new year all.
Odd one this. Came out the front door this morning to find the radiator cooling fan running full tilt. It only stopped once I'd unplugged it.
While this is not to drastic in the winter, l will need it when the warmer weather arrives.
Anyone know why this should happen and what l can do to fix it? Relay perhaps?
Grateful for any help and advice.
The car is a 1998 Felicia Fun.
Thanks all.
doesnit have AC? If not, then it's probably faulty thermal switch on the radiator.
I think the thermoswitch has fused it's contacts
If it's a signed speed a 5 euro part easily replaceable with a 29mm socket and ratchet.
But unplug the battery to avoid shorting the feed cable.
23 hours ago, funboy said:
Relay perhaps?
Mine is under the strut bar, below that black cap (on the passengers side).
I think it's 22mm.
1 hour ago, D.FYLAKTOS said:
22mm
Nooo  29 or 30
I have never used 30mm wrench in car repairs (i have changed my  thermoswitch in the past) because i never need to bought one.
Update: Yes it's 29mm, i just check it.
Edited by D.FYLAKTOS
No AC.
Do you know the part number of the switch please?
just buy a generic one dont bother with part numbers, find one in a temperature range you like and be done for
6U0959481A
Depends from the country that you living (climate)
Here mainly we use 80-85 'C (some with older cars in traffic areas use 75-80 'C ) ,if you live in a colder place then 85-90 'C etc
An example from the well know Mahle
https://www.trodo.com/temperature-switch-radiator-fan-mahle-original-tsw-4d
On 15/01/2023 at 22:18, D.FYLAKTOS said:
80-85
at what point of the gauge does your fan initiate?
The first time:
One click above 90 'C ( must be 91-92) and works for few seconds, less than a minute.
