Felicia 1.9D steering wheel swap
Hello all,
I bought an used steering wheel for my felicia to replace a two arm with the four arm steering wheel. Thing is the ring for the connector of the horn is bent (refer to image below). Is that the proper way for it to be or is it damaged? Thanks in advance
I took my chances and straightened the connector and then i was able to fit the part in the steering wheel.  Continuity test was ok . \m/
Sorry i saw this too late, i have opened mine many years ago because i had a problem with my horn.
No ''beep'' at all, the technician opened and i remember that this connector was for sure straight.
Yours maybe took an inclination while opening.
Most probably it was bent when trying to fit the back plate prior to sending. Just guessing. Either way i gave it a twist and got it in a more straight position to be able to inesrt through the hole.
