Octavia error codes on start up
Hi
Per this video, I am getting a lot of error codes on start up (sorry but I couldn't change the orientation):
This series of codes appeared several times before but only lasted for a few days and then went away, this time they appears every time I start the car for the past 4 or 5 weeks.
Since they previously appeared then disappeared, I assumed they were not validly showing any physical problem with my car.
Has anyone seen such instance of all these error appearing? and if so, what did you need to do to resolve it?
Thanks a lot
Fergal
What's your battery condition like?
Seconded re battery on its way out
Battery seems fine. Never struggles to start bought a new one approximately one and a half years ago
I'd still check just to make sue. It seems on modern cars it's other systems that start failing before car struggles to start. Power steering a common early symptom. At least measure the voltage before first starting to confirm all ok.
Thanks lads. I'll check the voltage today, what voltage should I be expecting started and unstarted?
Unstarted over 12V, just started probably over 14V.
It measures at 11.95v and 14.53v so battery looks ok
11.95v isn't particularly good, ideally it should be around 12.4 to 12.6.
Though my battery isn't that old and it's still a little lower than that, but not under 12v. We do a lot of short journeys though.
How long does it take to drop down to 12v after stopping?
11.95 is fine given that the OP has simply opened the bonnet and measured it without going through the tedious routine of foooling the ECU that the car is still closed and locked after 20 minutes, the Can gateway and several controllers will still be active dropping the voltage to below 12v. The magnitude of the current can be judged by the massive spark you get when you first connect the battery terminals.
The OP should be checking the battery terminals, earth lead  and starter connections as it sounds like there is excessive volt drop to the ECU and Can controllers on start up.
When this occurred several times before, during a drive all the warning lights would turn off and adaptive cruise control, Park Pilot would all function normally again.
However I have observed that within the same journey, all the warning lights could turn on again - it was very intermittent, now it seems permanent.
Originally, the warning lights seemed to coincide with when I washed the car - as if moisture was causing the issue, though it would also happen on dry days.
We had a very wet March here in Ireland and that was when the issue started again, though this may be just coincidental
Could be a faulty wheel speed sensor or connection to it?
Really best to do a fault code scan with VCDS or OBDeleven to get more useful diagnostic information.
Ok, I'll try get it booked in for a code scan
Where do you live, someone on here may be near by and can scan your car.
There's also a vcds map in the forum
Hi all. Thanks @FergalK for bringing this subject up. I have a 2015 Scout 2.0 tdi Combi and I have been getting almost the exact same range of errors in mine
My (many) simultaneous errors include the ECS, Tyre pressure loss, error in cornering lights (AFS) and an error in the Stop Start system.- my errors started only last week. So this looks a bit like planned obsolescence to me given that our vehicles are the same age 😀!!! I jest.
My almost identical problems started only appearing intermittently and disappearing - like you - on a damp morning - stopping when the engine warmed up. Now they are permanently displayed.
I ran an attached VCDS scan (report attached) which displayed a catalogue of errors - you might find it helpful for your own use case.
I find the suspicion that it may be the battery to be quite interesting though as my electric tailgate started playing up last week and no longer works - I didn’t think there was a link with these errors and the tailgate problem - but maybe there is? Interested in a solution guys! Cheers in advance.
(My battery reads as 12.36v at startup - and 14.3v once started)
error backup 1 Log-JDL875-TMBMK7NE5F0198351-168298km-104575mi.txt
thanks @spindlegridley, interesting to find out if any others have seen the same issue and if/how they were able to resolve it
Sounds very like an ABS wheel sensor to me - all those systems need to know wheel speed so them all appearing together strongly suggests that.
I had the same raft of faults on my previous Octavia and the cause was the right rear wheel speed sensor.
thanks @PetrolDave, I'll drop it in to the mechanic and advise of the suspicion of the ABS wheel sensor
I have had it once only, about 15 seconds after lihtly clipping a kerb with the right rear wheel when taking a corner too close not allowing for the different trajectory of the rear axle to the front.
Warnings went away when I recycled the ignition and have not come back, I checked the sensor connector visibly when I refitted the summer tyres, if I have problems in the future I will know what connector to suspect but a VCDS scan would confirm.
Thanks @PetrolDaveand @FergalK - My Octavia is due for an inspection service this month - and it needs new rotors and brake pads (related to other problems??) - so I will definitely get that checked out. Cheers. D
