Kodiaq RS inner sound actuator location?
Gents, does anybody have idea where inner sound actuator is located in Kodiaq RS? That pumped in audio in “Normal” mode is really annoying… I dont mind it outside. I just want to disconnect inner module… seems that it is not coming via sound system, as location is somewhere in boot area… (if is not ofcourse woofer on Canton system) I may code it out, but in that case also outer sound will disappear, but I kinda like it outside… 🙂
Edited by M8DSwordfish
Left rear bumper.
Hmm only outside and not inside…. As per manufacturer it shall be inside and outside under one coding… anyway tahnks linni, will check it out.
There is no sound from speakers. Just the soundaktor.
You can code it with OBD11. Default value is 100%, you can turn it down to 0% or some other level.
Not sure about 200% though :)
 I’ll take Your word for that, thanks! 👍
