Any real world benefit of fitting an Airtec intercooler to a Fabia 1.4 rs with stage 1 ?
Mulling this over as I'm about to replace my exhaust with a Tony banks system
On turbopetrol engines a better intercooler will increase torque and power irrespective of "Stage" because it allows more ignition advance and more fuel to be injected due to the lower charge temperatures.
A turbodiesel can't do the same trick because it doesn't have a closed loop wideband lambda system or knock sensors to provide data for the dynamic map.
A universal one will fit just the same at a fifth of the cost
 Inlet and outlet hose sizes & positioning ? height and thickness of cooler, mounting points surely they can't be the same as a bespoke unit ?
Thanks for the comment.
Have fitted a universal(chinese) one myself, does require an extra bit of mounting to the crash bar however it was pretty simple.
587E2098-EF60-4630-B40F-BCDD6EE50081.thumb.jpeg.a38f33ef9723c7933556cff439192c67.jpegBF69DEEE-3EEC-4446-93B7-780554389DB3.thumb.jpeg.2a33420f03ff63478f7459517278221b.jpeg
Works fine for £70
Edited by Mickmartin
@Mickmartin
