OneTouch Windows
Hi all,
What is the routine to reset the one-touch operation of windows?
Front passenger works on OneTouch closure, but not opening. Have tried to use the wind up, and then hold up, then wind down and hold down. As has been on all my other VW/Seat/Skodas.
It may be a faulty switch, we have two Superb is in the family and both are required new switches bought online for around €25 each. Not original parts but just as good.  Easy enough to fit yourself.
That should be the normal reset procedure.
Does one touch work on the passenger door switch or drivers?
I can’t remember if one touch works on the passenger switch or just drivers, if it should work on both but only works on one then the switch could be breaking
Front Driver’s, Rear Driver’s and Rear Passenger all operate fine, both up and down.
Front passenger side one touch up is fine, but one touch opening not working
Does it work from the front passenger switch itself?
That’s the one I noticed it from. Will have to check the passenger switch
