Engine mount passinger
Hi I was driving home from work and heard a bang luckily I was only going slow and near to my destination I noticed the passenger side of the engine was slanted I managed to take the engine mount off but I'm stuck on 2 things dose anybody know what it's called were the bolts have snapped and what size bults will it be
  • Sponsor
6R0 199 111 C  "Console" I think, unless your engine code is CLMA in which case it's suffix A instead of C. Check google images to be sure it's the right bit, please. Either is around £50 + VAT from Skoda.
The snapped bolts appear to be part number WHT 001 835, £2.51 + VAT each.
Had a clutch change recently?
Edited by Breezy_Pete
Missing a 1 in console part number, sorry
thank you Breezy_Pete you were bang on the part number and the bolts my car is back on the road thanks to you unfortunately i still have 2 issues that iv not solved  and haven't a clue what's causing them i thought that the bolts that was snapped was why the car was puling to the left but its still dose even had it tracked last week and they said it was perfect plus there is a mild knock when i go over a little bump i know its not the suspension and had the  anti roll bar linkages changed last year
thanks again for your help
