Faulty Rear Parking Sensors
Hello,
Wonder if you could help?  There's been a lot of useful information on here since I purchased my Superb....
Recently my rear parking sensors have died.  Completely not working.  No visuals on the display when selecting reverse, no warning sounds or otherwise, no beeps.....
I did find a thread here:
https://www.briskoda.net/forums/topic/442815-how-to-change-a-faulty-rear-parking-sensor/
Which advises to listen at the back of the four sensors.  In this instance however, all 4 sensors are ticking!  So I'm not sure if I have necessarily the same issue with a single broken sensor.
It's almost as if the function has been disabled/switched off.  Is there a button or menu for this that I may have inadvertantly pressed?  Otherwise is there anything else I can check?  Unfortuantely I don't have access to the code scanner/computer debug....
Thanks anyway for your help!
Find someone with VCDS, VCP, ODIS or OBD Eleven to check for the errors, this is the ONLY reliable way to have it checked.
