How do I unlock DSG transmission
Hi Folks,
I got replacement for my car mechantronics but after installation I’m getting P170100 error. Transmission locked. I would highly appreciate if someone could help me with this. I believe some coding needs to be done.. what are the tools I would for require for that? Or is there any paid virtual help I can get?
thanks in advance.
You would need ODIS as its the only tool that can do the routine required whether it is immobiliser service or component protection.
Sorry no idea but hopefully someone that might know might happen along.
Maybe @Crasher  or @ApertureS   EDIT>>>
What is the DSG, is it a DQ200?
Is this a new MCU, or refurbished or a used one?
Edited by toot
That looks like VIN based component protection so yes, ODOS is the only way I know of.
Thank you all for your valuable suggestions. Appreciate it.
You also can’t just go and buy the software and hardware yourself.
I mean you can get it, but you won’t be able to use it without a login.
and then you need a special security login to do what is required
