Satnav install - do i need the wiring?
My son is just about to take delivery of a 2015 Citigo monte carlo and he wants to get the Satnav unit and install it. I've read in some places that the car may come with the blanking plate but not necessarily the wiring is there an easy way to check before he buys a second hand garmin unit?
All the wiring is under the dashboard.
There should be plastic elbow that fits in the slot (cover plate removed) that holds the Garmin or other GPS.
Top Tip: If the original Garmin unit did not come with the car, just don't bother - they are no longer supported and are pretty rubbish. If you need GPS, buy a SatNav or use the phone with off-line maps, and plug into the cigar lighter.
