Mirrorlink Android Auto Carplay
Hi all after some help/advise my son as just got himself a 2015 Fabia and we have been trying to set up Android Auto with is phone can only find mirror link which does not work cant find Android Auto in the menu
Please see pic of head unit version
Any help would be appreciated
John
Because this unit (simplified Bolero part number 5Q0035820) support ONLY MirrorLink. To get Android Auto you MUST have the infotainment unit (SD card reader) retrofitted with a patched one. If you are interested pls contact me on PM.
I do have android auto, but only with cable. I want to get it wireless. I thought updating the system might do the trick. But in order to get wireless android auto, I need to retrofit the infotainment unit with a patched one? That means replacing the entire system?
If you already have wired Android Auto then just buy wireless android auto adapter - I recommend Motorola MA1.
Ah I hoped to achieve this through software update and not spend money for it, but I suppose I am limited with the hardware I got.
Thanks for taking your time to look into to this.
Hi Pab567
Yes i am  interested in this retrofitted with a patched one what would be the cost and are you UK based
I also have a 2015 fabia tried the mirror link with my iPhone 14 pro max not even recognising it but will recognise the usb connection for music through the unit. I went to Skoda dealer yesterday they said could possibly need an update of the head unit but wanted £100, basically just not interested, I found a head unit out of a 2017 fabia wondered whether that might have car play on it
Let us know how you get on
  • 5 weeks later...
i have Fabia Combi 2019 model...with wired Android auto.
The Head unit has built in Bluetooth which connects with my phone. My phone is physically wired to the headunit via USB as well.
With the above setup, Android auto works well.
To convert the above setup to Wirless AA, I bought a Wireless AA adaptor on Aliexpress ...https://www.aliexpress.com/item/1005005797338636.html?spm=a2g0o.order_list.order_list_main.5.21ef79d2UoDvJv&gatewayAdapt=glo2nld
I have now wired the adaptor instead of phone.
This adpator connects with my phone on bluetooth along with bluetooth of my Headunit, but Android Auto doesn't work on the headunit.
Has anyone faced this issue. Seek guidance
Can you please elaborate on this? I also have a unit with only mirrorlink and would like to have Android Auto. Do i need to replace the whole unit with a new one? Or only the SD card reader thing?
What is your unit part number?
This seems to be one of the cheap adapters that connect to the car via CarPlay and then emulate Android Auto for wireless connection so first check if you have CarPlay supported as well. Additionally, your phone must be capable of WiFi 5GHz band.
Here is my unit number
You need to replace  the SD card reader thing
Ok. When i look in the glove box I cant seem to find the SD card reader
It's located next to the glove box, behind the display, to see it you have to remove the glove box first.
Ok thank you.  I assume this the one you are referring to. Is it just to switch it and then you are ready to go?
Yes - but the new unit must be first patched. If you are interested in getting such patched unit pls contact me on PM.
  • 2 years later...
Hello,
I do have a unit : 5Q0035819 with the SD card reader in the glove box.
I’m interested to change it to be able to use CarPlay.
Can you contact me to discuss about it please ?.
25 minutes ago, Willbeat said:
Hello,
@pab567 can you help me with that ?
I can’t send you a PM since I’m new here.
Thanks !
PM sent
  • 3 months later...
On 23/02/2026 at 20:03, pab567 said:
PM sent
Im looking forward to get a patched unit myself, can you send me a PM as well?
PM sent
Hello@pab567 I am new here too so can't send a pm.
I have a 2015 Mk3 Fabia with a Bolero unit 5Q0035820. How can I upgrade this so I can get full Android Auto capability to use maps on my screen please.
Edited by Alidocious
@pab567
I would also like to upgrade my system to include Android Auto. I have a simple swing autoradio with a Bluetooth connection. I have heard that I will need to replace the infotainment system and the display. Could you please get in touch with me via PM? Thanks a lot!
