airbag reset
Hello everyone.
I hav a problem,i took my stearing wheel off to change my indicator stalk.But now when i put everthing back the airbag light will not go of.Do i need to take i to a dealers?
Anyone with vagcom should be able to turn it off for you. Where are you from?
I am from wigan
Well i am from yorkshire so not very local. Try searching in the vagcom and diagnostic forum
Get it fault read, you have to be very careful not to rotate the airbag link (the circular palstic bit that the loom plugs into) more than a certain amount, if you have it will need to be replaced.
