No power supply to Right Rear door
Sboahen
Recommended Posts
4 hours ago, Sboahen said:
For about 7 days now my right rear door doesn’t not unlock, window glass doesn’t work and speakers don’t work. Rest of the 3 door function normally. I need tech advise
It's probably a broken wire in the rubber bellows to that door. Taking it much further requires access to the car, and a multimeter.
  • Like 1
Link to comment
Share on other sites
  • Administrators
As above. It’s a looped system so the power etc piggy backs from the front with a connector in the b pillar.
You’ll need to check the loom and connector block.
Be sure to remove interior from the top down or you’ll snap all lugs, etc.
  • Like 2
Link to comment
  • 4 weeks later...
Hello, sorry to bump, did you manage to sort this? Mine has done the same after the heavy rain we had up here on Saturday. I changed my window regulator back in december and removed the plastic seal. Ever since I've noticed a small amount of water on the inside of that door.
I noticed today there is a small vibrating noise by the window button and the light flickers on and off when the ignition is on. Is there anything I could check before I force the door card off from
the inside?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
