Timely warning
My 2007 1.2HTP started idling rough, I at first blamed it on E10 petrol, then on morning really bad and I suspected an air leak so my first suspect was the servo vacuum pipe which I wiggled and imagine my shock when it broke off at the inlet manifold with just the slightest movement.
On inspection and replacement I found the whole pipe brittle at servo end and both sides of the non return valve.
My car only covered 70K miles but my advice to everybody with a plastic servo pipe of any age is to REPLACE IT .
Car idles and run a lot better now and MUCH SAFER.
Same issue on 1.2tsi. Hose going to pcv valve held on by hopes and dreams. Bought half a meter of silicone hose with 10mm id and cut from that. £4 fix with spares left over
