Pick-up transmission, manual
Hi
Someone know if the manual transmission in the petrol 1.3 Pickup is the same, as in some of the passenger Felicias?
There is a shortage of the pick up transmissions in Sweden.
A customer has just bought an other Pick up with no 3:rd gear as well as "hard to get in reverse" and it sure sounds from him, its a transmission change a head.
Thank you
Edited by Orchid70
Depending on the engine variant, there might be a difference in gear ratio (pickup being the shorter one), but for example all 50kW 1.3MPI are the same.
Yep, different gear ratios, there's a couple of topics here on it
If you're asking if they will physically fit, then yes, all the gearbox cases use the same mounting points, and are interchangeable.
