Battery died, replaced battery now power steering light won’t remove.
Hello, please help I had my battery die so I got a new battery as it could hold new charge but now the power steering light won’t come off I turned the wheel to the right full lock then to the left even did it the other way it still didn’t work. I have drove the car and in the past that has made it come off.
What more can I do 😭?
Hello Adam, normally, random faults after a battery replacement clear themselves - I suggest getting a diagnostic plugged in to check for any fault codes, then clear them.
@Warrior193i have a diagnosis scanner. For vw cars and under the steering wheel section. No codes come up and I click clear codes it doesn’t go ? After the battery was changed it used to come up but then would always go but now it doesn’t disappear
That may be the issue; "cheap scanners" are not supposed to clear latching fault codes like this.
  • Sponsor
Are you sure you're looking at the correct control unit? Steering Assist (VCDS module 44 under chassis tab, for cross-reference) rather than steering wheel, maybe?
If there is no real fault it will almost certainly clear itself after a few drive cycles though.
Edited by Breezy_Pete
I don’t have a vcds is there anyone in lincoln or near who does maybe Leicester as I come regular. I don’t know what it could be never used to happen. I don’t mind driving to someone who has vcds
Best to have a look on the VCDS map and make direct contact with someone local who has it:
Gaz
