Posted
Hi all,
Was just wondering if it's possible to retrofit the dual boot height floor?
Ta
I believe it needs different mouldings on the side of the boot to hold the floor in the two positions, so probably not a cheap option!
However the German Karoq forum has several threads describing how you can make a wooden frame around the sides of the boot to hold the floor in a higher position. (The translate feature in MS Edge does a good job of turning the threads into English for you.)
See www/karoqforum.de. (For some reason Briskoda won't let me copy the exact thread in here!!)
Chris
Edited by CJJE
Thanks, i'll check it out.
