Cabin filter inlet
Hi, can anyone with a MK3 confirm if the cabin filter inlet on the MK3 has a grille over it or is just a rectangular hole in the bulkhead (under the bonnet obviously)?
Thanks in advance.
Sorry I've never looked, have you a photo or have you not yet took off any plastic covers between bonnet and screen.  I think, IIRC, the earlier models were just a hole, but I sit to be corrected, and as the Mk1 and Mk2 seemed to be built better than the Mk3 I'd not expect the additional expense of a plastic cover for the Mk3, but I could well be wrong and my wife's car isn't here to look (and I'd not risk braking any plastic covers on my wife's car especially when it's cold, dark, autumn, unless was absolutely necessary).
Just a hole and you can see the fan/motor/workings.
Underneath the passenger wiper blade/ left hand side.
Thanks. AG Falco
Thanks. AG Falco
Thought as much, just had the drain hole in the wing blocked by leaves and you can see water marks up on the bulkhead. Passenger footwell carpet wet so I suspect it's come in through the gaping hole 🤨
Only last week I checked my neighbour's car for something like a blocked drain as there seemed to be a lot of condensation inside the car.  It was very easy to remove the plastic bonnet to windscreen cover and check and that too just had a hole but everything was bone dry in there, Sod's Law I then remembered the bathroom mat/towel thing in the boot.
I expect you already know to change the cabin filter and clean (and  dry?)  its housing as much as possible, that was the cause of the condensation in my neighbour's car a few years back.
Drying out the footwell carpet is a bit of a pain but very necessary as the Mk3 Fabia gets enough condensation as it is (if not garaged), I put the two Pingi
Car-Dehumidifier bags in my wife's only this weekend (other Pingi bags and other makes and products are available). -https://pingi.com/product-category/car-dehumidifiers/
Good luck.
  • 2 years later...
Hi all
Just high jacking this thread as I've been having a nightmare with condensation this winter.
Appears more than just normal condensation. Seems the VAG group cars all suffer with this problem having been trawling the web and threads on here.
I notice the passenger footwell carpet seems pretty damp say a month ago. Been trying to dry it all out ever since, airing the cabin when ever possible.
These drain holes in the plenum chamber, are they in the corners deep down in the wings?
I noticed a whole load of leaves down there, not sure how I'm going to remove them yet. Might involve a vacuum cleaner and a flexible pipe gaffer taped on the end...
How easy is it to lift up the plastic cover over the chamber, is it screwed down or anything?
I tried to look earlier in the dark with a torch, i think i found the inlet hole for the air blower. I think mine had a mesh over the front of it so not an open hole. But I'll check again tomorrow in day light.
I'll check the cabin filter and see what states that's in, if its soaking wet i guess that's a bit clue.
I'm going to run a dehumidifier in there tomorrow, i just cant get it dried out!
Had a problem for a while but seems much worse this year, its starting to smell damp in there.
I don't think its a leak with the door seals / card or windscreen seal but need to have a good look now. I have a memory of reading somewhere about the windscreen washer reservoir leaking or something that could also cause a damp passenger footwell? But maybe i imagined that...
Think I'll pick up some of those Pingi bags as well, seems like people have had good results with them.
Edited by Gonzini
