FAULT CODE P16CB
Hi everyone! Fault code P16C7 (heater support pump) appeared few weeks ago. Got it replaced but when I hot it out from the garage warning light appeared onbthe dashboard
Got it checked and fault code P16CB found, heater support pump supply voltage. What does it mean? Can anyone  please help me?
It means the garage has probably just throw a pump on it based on a fault code rather than actually diagnose if the pump is faulty, check all parts of the systems and go from there.
Unless you had the fault code and paid them to simply change the pump rather than diagnose the fault?
Hi ApertureS.
They check it and change the pump but not original. The fault code at first was P16C7. When they replaced it the code came out as P16CB supply voltage!
Things sorted! Pump replaced with ORIGINAL one and no warning light on the dashboard. Some parts of skoda needs to be original.
