Yeti front windows not working
Hi again Guys. So following Our yeti front electric windows stopped working which first started with the passenger side front and then the drivers also stopped . Everyone was convinced it was the usual loom doom. So I couldn't see any broken wires on the old loom but still replaced the door loom today with a brand new one and still both front windows wont operate! The switch operates the rear fine but nothing for both front doors. Passenger front door works fine from passenger side. Could it be the actual switch failed? Any ideas appreciated. Thanks.
  • Sponsor
Does your car have the feature where a sustained press on the 'unlock' button of the remote starts to drop all the electric windows (and vice-versa for the lock button if windows are left open after shutting all doors)? If it does, try it and see which windows move/don't
If it doesn't have that functionality on the fob, try turning and holding the key in the drivers door lock to try to achieve same. If all windows work, that would strongly implicate a switch fault.
Edited by Breezy_Pete
Thanks for the advice I shall try and see what happens.
Regards
Shane
