How to run lock
Hello guys, kind of new here, new owner of a octavia 3 facelift 2018. Is it possible to lock the car form outside with the engine running with VCDS coding? Do i need some module or just coding? I was looking in VCDS Coding tried and tested and didn't find anything like this. Thank you in advance for your answers!
There is a setting to change in VCDS to allow the vehicle to be locked with (presumably the spare) key when the engine is running, if you wanted to be able to remove the key and lock the doors with the engine running, you'd have to install a dedicated runlock system, and make the change in VCDS. I did it for my car a while back as I have a runlock system but can't find the post, will keep looking and add it here when found.
Here it is:
09 Cent electronics:
16 - Security Access - enter 31347
10 - Adaptations - ENG141651-ENG115754 -- ZV allgemein - Funk bei Klemme 15 ein - Set to active
I'm glad you brought this up as it's something I was planning to do on some Octavias in my company's fleet, and had forgotten the coding.
I forgot to mention, i have kessy, is this still avalible?
No clue I'm afraid, I suggest try it and found out, if it doesn't work then I'm not sure what adaptations need to be made
Ok, thank you very much, i ll try it tomorrow and let you guys know
Hello, so i finally did this to my car and it works perfectly with the setting SpaceWalrus gave me. For anyone that want to do it. I want to mention that i have kessy and for me it works, with the error that the key is not in the car and you can lock it/unlock it only with the buttons on the key.
