Car won't select a gear
Recommended Posts
Hi, my car will not select a gear when the engine is running, it deals a gear when engine turned off and if I try starting the engine with the car in gear and clutch pedal pressed down the car jolts forward.
Further info drove the car though a large puddle last night and continued on my journey home for a further 20 miles changing gears with no problem.
Link to comment
Share on other sites
Sounds like clutch stuck to flywheel due to driving through puddle. . Try selecting gear start engine when car lurches forward press clutch and slam on foot brake or handbrake and clutch should release
  • Like 2
Link to comment
Thanks Kenny R, that worked perfectly, so no more going through large puddles I will just reroute 👍
  • Like 1
Link to comment
Wow! Every day is a learning day!
It certainly sounded exactly like a rusted and stuck clutch plate but I have never known it occur overnight, it usually takes weeks/months, I even posted that view very recently, granted that is from airborn moisture and yours got a soaking but that is ultra quick.
I have just seen from your location that you are in the North, did the problem occur after a freezing night perhaps?
I'm really pleased you resolved it and 👍to Kenny!
Link to comment
Yes we had a lot of rain over a couple of preceding days but the temperature dropped quickly during the night.
I've had the car from new and that's the first problem I've had with it.
Link to comment
I thought the clutch was a sealed unit, so how did the water get in.
BTW, know very little about anything underneath.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
