Octavia Vrs 2023 - Moisture/condensation in Matrix headlights
Filip222
Hi forum. Anyone have similar problems? Driving at night with fogged matrix headlights is bit of problem. It happens every time when it rains or in carwash after engine is hot on both lamps.
Octavia Vrs Tsi 2023. I assume they will replace at dealer.
I don't know Croatian consumer rights law, but in the EU and UK a new car warranty would apply and the replacement would be at no cost to you.
Croatia's in the EU - even adopted the Euro earlier this year.
It is normal, from page 50 in the owners manual, under Troubleshooting:
The headlights are misted up on the inside
Inside the headlights, moisture may occur. This is not
a defect.
Edited by CS363
You need to see actual full droplets for them to do anything. My front right headlight was recently replaced, I had water in it and even visible dust. Later on it fully cracked while I was waiting for the part to arrive at the dealer.
ABLVV87J3aK4auTbNS1jTKBmf9qvy9hNZ948_HQoF8JK2oCndBRoP9Cmob41HARavbI02qEhgRzIyYa2xN5poQY1lHXlRC6YlLjx2b30_q6DiZGmyb7HsmgSgFNJFbHXHR_iaMJcoCL1SfFMBuHe62kzfht27NF7ho-08aw3gHiSQ-nyub5FFq8l8uKokXU9nEhg_1ugDvtq69HfxP9rpRGzBHH5ZhknV9macyLt5iWY7tHpDM7G5BXaolBXuY92pljtLzpKblM43bO9Y5hVQJIcadgnXDnsb_63FeaGRN9HHxVL-usVzvAIfTFig5N7PZ_mqIt9CDm8C4f_uJM_e7fFuOF-NjwxImhhj1LnkUtRGEmaJXOcfa3OTsNhNBcro648WwNS-zUjGq3nxNo7aezgu7npXdze4FXsqUu5XQ0UCkWrYBSVy8AfF_kSrryTVXjlRLVPyh8MGIgvy2aHd3a85dC0lRV4dWwaAYF_Rr5pVI6iAlOnM3qy4Aew7TDXpk-GWIJEanfUVSfgVi8bqgj5yDF95TlyYsSmJIMrxtpUForqiovEZzhWNJUodQv8ozUlHyVIl6EJTP2TW8zp1WfoOP7UDYQKJneFJsSTiVgfie064r_e8Xny7QKH7wdDchBVmLNe35MSvChC0kpXW94z2FtBX4Cs3GeIiskovi67GRGeFTzVGve3GsviISV9pfo7LeJvSLJJwURGAihk8J_6hOTCOGo4Oi6gbX73w4Sz1eI5UHr1XBBw2wuj1fLGduCHbJbQ0jx7CbOqgotBah7sfgjcQ8rOn9nQ3W7Md7ifyQvxtmD-ZOsIF12Qvs8JrnzUYPUv8gdowErZCvJtoNoOFxexhCw6ONVpMTct6PVbdlmscrBGB5RvjT6MaszTzYGx14hSCl7FzWtrLhSpGY6lzpW3HzsPkK9UnEhGY-YY=w1695-h1271-s-no-gm?authuser=0
ABLVV85VXc2IHFmRQUPQs1-USZDer-AOhY3s8exXmN9PECwgvm9q659pWvCFlfzqPG_TY0mXoiV1iOkp5j9VhgTWwSPqr_M2OBL656y5Yt3bHKk-134aXnl5NwUaJCGmbU3LtplWXhQ-ORqvHmF63FS4Z-mD5JlgYmaC42yF0Oy1a7bolvaeFFLrTCgZYDc3pcTFL5TwRmEk0LcMhhCTX_OPHvOLSUf0IRF9TWU2NRJpFAyyTrWnev6QOtOpM48wmZRlc0XxSKzaYrSoOdCRHl14p-yW9om7WuBjqy1I3GSTTNuTL9hbVAIU1q_AjYNQE-MZVjcHGQHxHOnA6cUks6V-M0Teaq2ss_-yMW-KTl1v0dmJTJYXPfcwiqY8NPar9xZHaMzT9ml8GDYivcindhuz7d-0jIY2qQ5GwRsZm10dr6itZACndSTj3lnPApTRC6I5NZTQhGJ6E-wtbDR-XMxzGp7KiR-j9v6ugFXtNO0a4zJaSc3uT1vR12qRSjeUa4pAdPAy9x2hDnWimrJfdG-0Zfxjwt0abB8eMHAChy-UqaxB8wSn1tX0sas-7tacs47gsBrF4JQ_uplAUtHeq-KUguf3NHwxYR0VgEHuhtWDu_coOugmKckdclAofD4NhREh48MqcRxpAQHkeAsNotVXxHjUw_pv5uBFfJ8zxoF4XxA3MnhB1sxiVGp2jsOGa84Jd__nisZf0jiZNsCrVceFiAHWxsZbYtOkZm25Yk-2jv4aB9zwKMFER5lmJEiA6ZRpX3nPi_mbMTeuidDLrkGd2nUpDQJdSVV4KpaYyYkuMav7I4qiwB2Ij-rpl3fS71pMwxZiYJ7fyf1dxCTR0Z6Hy83IcBIXJt4uCHOTIIW_jgUoN1Clny0NUm9t0rSyxfrHH5JbLFb83hVHzXNWb_ttpieiNpXayeomkWyZx9fyVA=w1695-h1271-s-no-gm?authuser=0
cracked, no damage whatsoever to the car, but looks like it cracked exactly on the line where all the water sits when hood is closed.
ABLVV849iNCdv9FJMi-Bk9Se7ZPM27sp31CxMxHrySYwehmCzQ_SyiY4ZYk4wxXEFtvuTeFLCG1h3TjxILjmFq90XqBJUMHIMCksKIOuhJ9iMVh0hGgMFCRCfJltJCWfO7SxDHHAIxHVzVRXJZLR3osEMzs45oNcjG2DvU5nD-G6YuazQVAjbyWrOLVyKju07t3WcEAKAWaxm0SC4yZLHKlvq_0SFjHHLU7K2O6AvL1LJnx58axDbVBQwEHjJUiQHwRaXNlPCXPuJ295i9Sc-SfsCbaSP6WaFXAKINcL2NW91-XKMwbqj3HhC65PXOKi8kt3WUrr0OVhaiBLiMw5qXDNHvnWNGk8AnsCEkPWQTzTGmXOcxnEPghU_M9iobOhd06krEpF2qNN2z8WPJXNwSEsRzFGX_UC-G8g672mbRma1PnrXSED3QC7Q-LVlxSIlSo-bx7qcheVuPDHHP_jtvnzpDZqaZrt5T1UJgnq_SjV79m3URMKrNjFb7BS2sWPo9EYAteQIO_sW7q8oq1F8beIkC69jp4P2-MLVtuMHqfkiST2MDhoz-E3xQ3nFLwsKjoB9z4Z_vTmgr7IHQmoO-i6uirFKsyLDZu7pRrPsmQz8McCgHPpfIHzloGNlNrPUw_LS7sjsjACdYFOU4unVenPw1LVxzJ9y251pBAgS2SMQ0Sq7t91WTOcEEVdJe2iijmho56uhaeU4H3Eph_J0qoeygqwF5s6CYOKi7KHKK8XC5U8zWKWqKy838MlNwTcSujXOuKzSGjeloiOtXKaLjWSQdz4_L4elwF6UkLlSnZk4LFZEqfhy45zdXHFrffkyU9cCth_g5ItcsGA7fHw7R4fyrYPYEVmQpoppXO47IacFap02ITj3aUz5Rb6gGop5H_SFRvWZNHfCeRodEDpGhJZ2F1Tjm1h3_2uUHZiTSBxfA=w2560-h763-s-no-gm?authuser=0
replaced, hopefully it doesn't happen again...
here is an earlier post in the forum with similar discussion
Edited by zetzet
ok kompa imam 2 takve rs- i svaka je imalaprblem iako nema kapljica vode ili da pliva onda forget about it. postoji 2 riješenja - 1 . probušiti rupu na faru sa zadnje donje strane ili bezbolnije nabavi foliju za stakla kao ppv za zaštitu fara. nema magle i imaš zaštitu.
so basic no warranty can cover this unless there is water in hedlights. but u can use ppv for protection. there will be no more fog
  • Sad 1
