First road trip. Low revs. Tyre warning.
Finally took my octavia VRS on a road trip from Sydney to Melbourne. Cruise set at 113kms. Revs noted at below 2000rpm about 1700rpm which i was very surprised i thought it would be in the 2000. The car felt extremely smooth and controlled,  very comfortable.  I'm very happy i broke the car in and had oil and filter change at 1500kms. 9 hour trip felt like just 2 hours. Was very very happy with it. Gave a fuel economy reading of 6.2l/100km with city driving included. This car is best on a highway. The only thing was, when i went passed 120km for a few brief moments a warning flashed saying something like top speed for winter tyres exceeded. I believe they are Bridgestone but I'll need to take a look at them more closely.  Do others get similar warning like this as well. I'll be interested to know.
Edited by LuxoviaRS
  • LuxoviaRS changed the title to First road trip. Low revs. Tyre warning.
Just search in settings for winter tyre warning option and turn it off.
- or set it to a point you don't usually wish to exceed.
Ok thanks,  i will do that.  I didn't know that was an option. By the way is it normal for revs to sit that low,  even with accelation it was pretty low.  I guess I'm not used to it.
Oh OK i have that option as well. I guess i need to refer to the manual to see how.  Thank you too
I assume you have something like a 2.0 litre TSI 245 or more - I only have a lowly 1.4 150PS - these engines have very good torque and yours will likely have a pretty high final gear ratio.
Edited by Warrior193
correction
I reckon Škoda have prioritised the gear ratios for low emissions and lower fuel consumption, hence lower revs when cruising.
Is your a manual 'box or auto/DSG? From memory, at steady motorway speeds the revs in a loan DSG I had a while back were lower than my manual 'box.
Yes that's right 2.0 L TSI 245hp. Ut has a pretty high gear ratio wasn't expecting it,  i guess never experienced it so high in previous cars. What does your one sit at
Yes it would seem so,  which is a good thing. I didn't try sports mode though,  i wonder if that would have made a difference. I had it on comfort or eco. Next time I'll try normal, sport and  individual. I wonder though do that drive modes actually make a difference.
DSG 7 speed. Oh ok even lower than the manual. What was your experience with it,  did you like it , did you have any issues with it.
Sports mode with DSG will move the shift points up the rev band a fair bit, and should sharpen the throttle and steering response - the dampers too, if you have active suspension (DCC?)
From a very long time ago, I seem to recall that cars shipped to OZ from the Mother Country were often identical to home model - apart from being given a lower final drive gear ratio.
I can't recall actual RPM figures of my Octavia at 80 plus - er - '72MPH officer, why do you ask'? - but the M6 1.4 is a pretty lazy cruiser - considering having to change-down for an overtake is extremely rare for me.
It was a very comfortable and easy drive; the 'box would change readily down if I needed the extra rpm for acceleration. I was surprised that the DSG 'box was as economical as my manual.
