Reverse camera on mib2gp
Hello
How can i add a reverse camera to the mib2 gp multimedia?
I have tried the following kit from aliexpress and its not working when pulling to reverse..
I dont need android or mirrorlink, just a backup camera 😞 please helpScreenshot_20240117-190753_Gallery.thumb.jpg.740fe3b9023b95a198eec764de2f8eca.jpgScreenshot_20240117-190217_AliExpress.thumb.jpg.c60060c6b59e4d0aa46678c8b08e5477.jpgScreenshot_20240117-190758_Gallery.thumb.jpg.88dedf8e43e81850656829544749a283.jpg
Have you coded the camera with vcds?
I had to do it on my mib2
Edited by nickytheshaft
No
Can you explain how?
I suggest you look at the rest of the forum. If you look at the coding modifications, then you should find what you are looking for.
On 20/01/2024 at 09:53, itami said:
No
Well you need a vcds cable and pc to access the car settings.
Then you have yi to tell the car that you have added a camera for it to work.
5F Infotainment > 07 Long Coding > Byte 19 enable Bit 4 reverse_camera_low
I know AliExpress has a camera that you can mount without coding as ot sends the info to the car
