1.9 PD Rocker cover leak?
I would appreciate some feedback on the cure to a rocker cover leak.
I have the original Skoda cover which is bowed and leaks down the rear of the engine on the tandem pump side.  I have already re fitted it with a new gasket and added additional silicone on retaining bolt seals plus additional silicone around the main gasket.
Time for a new aftermarket cover which I notice have additional ribs to stop distortion.  Can anyone recommend a manufacturer and is the any tips on fitting?
Can someone please help me. I'm trying to find within Techies downloads, the fitting instructions for the PD rocker cover. I've seen one for a latter Golf and it gives tightening sequence and location for additional silicone.
Not sure if there's anything useful in the official workshop manual, but maybe worth a look.
MK1 Fabia workshop manuals - SKODA Fabia - BRISKODA
Eleventh file in list. Engine mechanicals 1.9-74kW
Oil leakage may be a symptom of underlying faults with the crankcase ventilation system, causing excess pressure.
Edited by Breezy_Pete
No joy but thanks Breezy_Pete. I have just found what I believe is the procedure for a PD engine. The bolt torque is 10Nm
The procedure is engine dependant, not vehicle dependant so the Golf instructions will be fine.
10NM is very low and many Fisher-Price torque wrenches used by amateurs don't go that low, this is often why the covers end up distorted.
You make a very good point with my original cover having about 2mm distortion and I have read of people stripping threads...... New aftermarket cover going on this week and I will be using a 1/4 drive torque wrench but not a Fisher Price one! Bit by bit my oil consumption is dropping
